We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi All,
I was wondering if it's possible to use a passphrase for the WiFi password (PSK). Is there a limit on characters?
Solved! Go to solution.
WPA2-PSK key must be between 8 and 63 characters long. Dashboard checks this is met, when you attempt to save your key.
