Which Meraki accesspoint can be used instead of Cisco AIR-AP1852i-E-K9 (similar coverage)?
Raphael
Hi, which WLAN access point from Meraki has the same or almost similar signal spread, coverage and performance as the AIR-AP1852i-E-K9 from Cisco? Customer will using the Accesspoint for Voice and Data applications.
The Customer did a WLAN site survey for Cisco AIR-AP1852i-E-K9 and likes to go with Meraki . Which Accesspoint should he choose? MR42/MR52... .? What would you recommend? Thanks in advance, best regards, Raphael
1 Reply 1
MichelRueger
Hi Raphael,
I just checked the Data-sheet of the 1852i and there are  some key Point's :
4x4 MIMO
IEEE’s new 802.11ac Wave 2
I would consider the MR52 as he is Internal Antenna as the 1852i and has also 4x4 Mimi Wave 2 and two gigabit ethernet LAN connection.
Regards Michel Rueger
