When is MR 32.1.4 released?
scottwave
Need per group SSID to enable use of 802.11be.
6 Replies 6
Mloraditch
Planned future releases are not shared publicly usually. For a point release such as this, support MIGHT be able to tell you an eta. Your account rep may also be able to tell you.
Occasionally a Meraki employee may share here, but the above avenues are more likely to be fruitful.
The latest version available is MR 32.1.3, how do you know that this will be available in version MR 32.1.4 if there are no release notes available yet?
scottwave
It mentions the new version here: it in this doc Wi-Fi_Basics_and_Best_Practices/WPA3_Encryption_and_Configuration_Guide
"Note: Per-group SSID configuration is available starting in MR 32.1.4. In earlier releases (MR 31.1.x through MR 32.1.3), all SSIDs transmitted by the AP were required to be Wi-Fi 7 compliant. If even one SSID was not security-compliant with Wi-Fi 7, the AP’s capability was restricted to Wi-Fi 6."
Indeed, as @Mloraditch  said this is not shared publicly.
Brash
As stated above, typically this info isn't shared publicly as releases can end up being delayed for a variety of reasons.
However, I suggest checking with your account manager if it's a specific feature you're waiting for. They can often give a rough framing of when it may be released.
RaphaelL
The version is out
