Want to setup Access points to our LAN environments
Indian1
Hi Team,
I am new to deploy  cisco Meraki access point in our LAN environment, the question is how can I set up these things, please refer the diagram for your reference.
Question 1- How can we configure access points to get internet so that all wifi users can access internet from their phone and laptop.
Question 2- I want to configure NAT mode and Bridge Mode for assigning the IP addresses to clients.
Your answer would be much appreciable
Here is the documentaion with the first steps.
https://documentation.meraki.com/MR/MR_Quick_Start
Note that the access points need to have internet connection to communicate with Meraki Cloud.
Here is all the useful documentation you need.
https://documentation.meraki.com/MR/Encryption_and_Authentication
1) Claim the devices and serial numbers into your organisation
2) Add the devices to your network
3) Create one or more SSIDs with authorisation methods etc.
4) Plug in the devices
5) Connect to the SSID
There are many more configuration steps that you can do, but essentially that will get you started.
