WPA3-Personal issue for Android and Ios
Forrest
Hi folks,
I have a wireless network including 11 Meraki MR APs (9 MR33 and 2 MR36)
They all have latest firmware MR30.6
the SSID used to have WPA2-Personal (with PSK) and it worked pretty well.
A few days ago I modified it into WPA3-Personal (PSK).
I've tested with our Windows11 mobile computers and they all connect smoothlessly.
Our Android devices don't, altough they are almost new: Samsung A54 (Android 13), Samsung Galaxy Tab S6 Lite (also Android 13). They don't show any error, they just don't connect. According to specs they are capable of WPA3.
A user also tried with the newest iPhone 15 and it didn't work neither.
When i look in Connection Logs (Wireless>Access Points -> Connection Log tab: I see no error whatsoever.
I've set it to WPA3 only & 802.11r Enabled.
I've tried it with WPA3-Transition mode also, but I had still the same issue.
Anyone has encountered this situation before? Or could lead me in the right direction?
I don't know if I should modify something on the wireless clients (hopely not, there are a lot) or if I should modify my wireless network.
Kind regards,
Erik
GreenMan
Meraki Alumni (Retired)
Did you try it wihout 11r?
I just did a quick test and my Samsung (somewhat to my surprise) carried on working quite happily when I changed the SSID from WAP2 to WPA3
Note I'm running with a CW9164 on 30.6 firmware
10 Replies 10
GreenMan
KarstenI
As mentioned by @GreenMan, with Passphrase based WLANs, 802.1r is not that relevant. It saves a round-trip time when roaming, but roaming is typically fast enough without.
Other than that, I am running WPA3 Personal and Enterprise with the major operating systems without relevant problems.
And:
With regards to security: nothing good ever comes out of transition modes (ever)
(Quote from Stephen Orr, Distinguished Systems Engineer, Cisco)
I have an SSID running WPA3 only with Pak and 802.11r.  My S22 Ultra connects to it okay most of the time...   APs are CW9166 and CW9163 running r31 beta.
bitkiller
Is it still 5GHz or did you b.t.w. switched also to 6GHz?
JeT
GreenMan
None of the access points that @Forrest has are 6 GHz capable   (MR36 are WiFi6, not WIFi6E)
I enabled 6GHz (indoors only in the UK), but so far I've only seen connections on 2.4 and 5 bands.
KarstenI
Accidentally configured a device restriction to 5GHz? My 6GHz capable clients connect happily with 6GHz.
And I miss a nice connection statistics view (as it is available in Mist) on the Meraki platform.
bitkiller
Did you try out to forget WiFi-Settings and reconnect to the same WiFi as a new one?
JeT
I have had nothing but terrible compatibility and reliability issues using WPA3.
IoT devices needs a lot more time till they get their stacks right.
Forrest
By disablin 802.11, it sees to work smoothly. Thx Greenman & Karsten!
I'm going to test the roaming part now, I hope you're right Karsten.
Btw: my APs are indeed not 6GHz capable like Greenman cleverly noticed.
