WLAN temporal Voucher
Jonathan_Galvez
Hi team,
my customer ask me if it is possible to have a temporal voucher from meraki.
For example: The receptionist should be able to create a voucher for temporal WLAN use (only for one hour for example). They do not want this users to manage the whole user list, so a embassador isn't an option. They also ask if would be possible to activate these Vouchers more times on a day.
Regards,
Jonathan
GreenMan
Meraki Alumni (Retired)
Sponsored Guest would be an alternative approach to this request..?    Just put the Reception email in an easy-to-access spot on the desk - and maybe create one that doesn't reference the main company domain name, if you don't want other employees to be able to approve?  https://documentation.meraki.com/MR/Encryption_and_Authentication/Sponsored_Guest
Yes you can, take a look at this.
 Note: Use fast prepaid login page
https://documentation.meraki.com/MR/MR_Splash_Page/Configuring_a_Prepaid_Card_Billing_SSID
https://documentation.meraki.com/MR/MR_Splash_Page/Billing_for_Wireless_Access
You can create a Guest Ambassadors, but I'm not sure if Guest Ambassadors can manage  the vochers.
https://meraki.cisco.com/blog/2013/05/guest-ambassadors-providing-simple-and-secure-guest-access/
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Managing_Dashboard...
I just confirmed that Guest Ambassadors are not able manage  the vouchers.
GreenMan
Jonathan_Galvez
Thank you for your responses, I will have a look and let you know if it helps!!!
