Uk regulatory domain 5725-5850 band C (Unii-3) and Ofcom license
Bgammon
Just a query has anyone applied for the license through offcom and actively using this on the meraki portal?
https://www.ofcom.org.uk/spectrum/radio-equipment/fixed-wireless-access
Is there anyway to mark that you have this license and plan to use this range and tie it to your license within meraki?
Just curious on anyones experience with this.
Also is there anyway to see the settings contained within your regulatory domain?  Might be more a feature request but would be great to see what is actually the limits set by the regulatory domain you are in.  Limiting ranges on the power based on this domain.  It is a little misleading letting you set to above what you are actually capable of getting.
The api call for regulatory domain just advises which domain they are set against.
The best doc I could find on ofcom was:
https://www.ofcom.org.uk/siteassets/resources/documents/spectrum/spectrum-information/ofcom-informat...
2 Replies 2
rsage_voda
Hi my organisation has a license on the Ofcom Portal for Band C Fixed Wireless Access as we deploy CURWB at a number of large construction sites around the UK to act as bridges between Meraki networks. We have to register the CURWBs on the Ofcom portal.
rsage_voda
Further to my earlier email here is the link to the form to apply for 5.8GHz Band C License https://www.ofcom.org.uk/siteassets/resources/documents/manage-your-licence/fixed-wireless-access/5....
