This device is using a DHCP IP address from VLAN 0 instead of using configured VLAN 1
ChrisL2021
Hi there,
    I have this error on my MR on meraki dashboard:
"This device is using a DHCP IP address from VLAN 0 instead of using configured VLAN 1"
How do I set the native vlan to vlan 1? I only configure vlan 1 for DHCP.
How do i resolve this issue?
If you have a switchport with native vlan 1. Then leave  the vlan field of the ap management empty
5 Replies 5
Here.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
ChrisL2021
    No it didn't help to solve the issue
Open a support case.
ChrisL2021
HI all,
   With Meraki support's advice, I managed to solve the issue.
Wireless > Access Point, on AP's LAN IP tab, set the type to "DHCP" and the important part is to leave the "VLAN" field empty!!
