Suggestions on how to mount MR to exposed truss ceiling
EMU_IT
We have a couple rooms with exposed truss ceilings.  Our old APs have their brackets wire-tied to the bottom of the truss.  Does anyone have any better suggestions for mounting the Meraki MR44 to this type of ceiling?
EMU_IT
I ended up deciding to wall-mount the APs instead.
Ideally, you should be able to install a bracket that is not in the line of sight of light fixtures and beams.
https://documentation.meraki.com/Platform_Management/Dashboard_Administration/Design_and_Configure/A...
BlakeRichardson
Time to practise your welding skills 😎
EMU_IT
