Congrats on phasing out the older model APs and welcome the newer model APs.
I’m sure you will have a mixed response on disabling 2.4GHz.
Being that this deployment is a school environment, I would NOT disable 2.4GHz completely.  I would selectively sprinkle 2.4GHz here/there for those who might not have newer mobile devices to include IoT devices (thermostats, sensors, cameras).  You would likely know and understand what all devices on your network require 2.4GHz better than I.
2.4GHz tends to offers greater range and tends to penetrate more spaces (walls/obstacles).  You might consider taking a few of the MR56s for your dedicated 2.4GHz range depending on how spread out your campus is.
Ideally, a site survey would probably give you a better understanding of the new APs coverage/overlap and if you need to space the APs closer with most of the new APs at the 6 and 6E ranges.
I have no doubt that the 2.4GHz spectrum is likely congested (everywhere) but a school environment would likely have some older devices connecting to your environment - I would think, I could be wrong tho.  Some academic institutions have an IT Policy that states or indicates your mobile devices must be at a min 5GHz or higher to alleviate numerous SSIDs and a heavily congested spectrum.
Just my 2 cents.  Hopefully a few others will share their perspectives.
