Struggeling internal IP's after POC deployment
thomasg94
Hi
I received a Demo-Kit with an MR33 Access Point - which was installed really simple and fast.
We are using a local Windows DHCP server why we set the AP into bridge mode with dot1x authentication.
Authentication is successful and now the problem begins.
Internet traffic is working fine - alle internal IP's are not reachable (--> redirected to 10.128.128.128) - also my Default Gateway is not reachable.
Thanks for your help
BR
Thomas
I think @Seshu  is likely to be right.  It should look like this:
MarcP
Did you try using a static IP? Still happening?
Strange it is redirecting you to the local status page of the MR...
Shouldn´t be in by default, but maybe it is:
Seshu
@thomasg94 Please go to Wireless -> Firewall and Traffic Shaping and make sure Local LAN is allowed for L3 Firewall rules.
NolanHerring
Double check the access control setting is bridge-mode and not NAT mode
Nolan Herring | nolanwifi.com
TwitterLinkedIn
