Steps to enable MLO
jrhop
Steps to enable MLO
Hello, I cant see to find any documentation on the steps required to enable MLO on Meraki, somewhere it says enabled by default, if so how to you disable it? I would assume the settings would be in the 'Radio settings' area. Can anyone shed any light on this?
5 Replies 5
Here is it.
CW9176I Installation Guide - Cisco Meraki Documentation
jrhop
Thanks @alemabrahao thats the overall setting for WiFi7 / 892.11be, what if you didn’t want MLO enabled?
In order for Wi-Fi 7 clients to connect at 11be rates or perform MLO (Multi-Link operation), 802.11be must be explicitly enabled in the Meraki Dashboard.
There is no option to enable or disable just MLO.
One more thing, this is mandatory feature for Wi-Fi 7 certification.
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Wi-Fi_7_%28802.11be%29_Technical...
jrhop
Thanks, mandatory to offer it. But most other vendors allow you turn it off/on separately to WiFi 7 being enabled or not.
