Splash-page doesn´t appear with iPhones since IOS 11.3 and 11.4 with Cisco ISE Guet-WiFi
redsector
We have an problem with our guest WiFi. The splashpage from the ISE doesn´t appear for signing in.
With Windows notebooks, Android devices and Apple Notebooks it´s working well but not with Apple iPhones (from IOS 11.3 and 11.4).
Its working with the iPhones on Cisco Controller based wireless LAN conncted to the same ISE.
Has anybody problems with iPhones and Meraki and Cisco ISE?
redsector
After weeks spending with support and a Cisco Case Cisco made a patch on our Cisco-ISE.
It´s working better now, not perfect but better.
Now we have this ISE versions:
Version: 2.2.0.470
Patch Information: 1,2,7,8,9
7 Replies 7
Mikanator
if you are using a self-signed cert in ISE, your users might be getting a warning on the cert before joining.  a good test would be to try to join via an android phone that either has never joined and or delete the ssid (and cert) and see if it give you a cert warning.
ccnewmeraki
Do you have *.apple.com in the walled garden list on your Guest WiFi? If you do, remove it.
If the iPhone can get to apple.com it doesn't show the splashpage until the user opens a browser and tries to go to a non-HTTPS website (which are surprisingly tricky to find these days).
I don't know why meraki added this as a default entry, it makes the experience worse for apple devices.
mo_unify
Further to this, Apple's WiFi detection is simple, it'll try to connect to:
http://captive.apple.com/hotspot-detect.html
If it does not get a success reply, the captive web portal browser will appear which will redirect to either Meraki's Authentication splash or a customer Radius Authentication service.
So if your walled garden is allowing access to *.apple.com, the Apple device will think that you have access to the internet without authentication and continue as normal. However the user won't be prompted to authenticate until they try to visit a non https site.
Mikanator
You might want to also check the FW rules in the Meraki help section.  The Apple systems manager is listed there.
redsector
Version: 2.2.0.470
jjonessec
running ISE 2.7, patch 1,2,3
issue is back on apple iphone IOS 14.6, browser unsupported
Berkeleycowboy
I'm running Cisco ISE 2.7.0.356 patch 7 with the same issue.
Receiving "Your browser is currently unsupported" on a test iPhone running IOS 16.0.3
Will be opening a ticket with Cisco to hopefully shed light.
