Splash Page java problem
Kebun
As we know some browser stop their support for java that will be use to direct to slpash page. use default browser sometimes have problem to run java. it takes long time to java to run.
is there any options to not use java in meraki.? or any suggest to resolve that.
I think only the antivirus check needs java. Nothing else. Turn this off and java is not used.
If you have Systems Manager you can assign policy bar on antivirus being installed.
1 Reply 1
