- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Splash Authentication events in logs but Splash Authentication is not configured
We are seeing Splash Authentication events in the logs but we don't have splash authentication configured for the wireless. Many times after a Splash Authentication event appears in the logs we find the client is blacklisted. What can cause these events when the authentication method is not even configured?
Mar 21 19:41:58 | Office 233 | Our-WiFi | HP-Laptop | Splash authentication | duration: 2592000 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Check if that client is blacklisted/blocked by chance. Also just check access control one more time to be sure there isn't anything off in your config.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The clients quite often get blacklisted after this event. I have checked, rechecked access control. There is not Splash authentication on this SSID or any other. I do appreciate the response, thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is strange.
Could you try upgrading the firmware to Latest Stable? If already not.
Ajit
AjitsNW@gmail.com
www.ajit.network
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi
I get the same problem on my network, do you find any solution to this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, I'm having the same problem.
Has anyone had an answer to this problem?
