Set specific SSIDs on specific APs
AdamB1
I know I can tag APs and select groups of tags I want an SSID to be broadcasted on.
However, I would like to do the opposite, i.e. select an AP and then choose what SSIDs I want to be broadcasted on that AP. Is that possible?
Best regards,
Adam
kYutobi
You would have to create Tags with the name if the SSID's and assign them to the AP you'd like them to broadcast on. If you're trying to go that route. That way you know what SSID's are grouped to the AP's you assigned.
Enthusiast
1 Reply 1
kYutobi
Enthusiast
