Seeing sponsors on Sponsored logins.
Caleb_Murphy
Hey everyone if this has been answered I apologize, but here is my issue. My org runs an SSID with a sponsored login. Its recently come up that we need to be able to see who authorized the login by seeing what email was used to sponsor. Meraki says this isn't a feature that Meraki supports so I wondered if anyone else had this issue or had a solution they liked.
Thanks in advance.
Caleb
As informed by Meraki support It's not supported. I think that the best solution for your case is the Cisco ISE.
https://www.cisco.com/c/en/us/td/docs/security/ise/3-1/sponsor_portal/b_spons_sponsorportluserguide_...
Caleb_Murphy
Thanks I will take a look at this.
EnricoPa
Hello Caleb, have a look on this https://apps.meraki.io/en-US/apps/412605/backloop---sponsored-guest-access  maybe can help you. Multiple customers asked us the same things so I decided to develop it as 3rd party page.
