- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
SSIDs not seen by some devices
Ripped and replaced a pair of UBNT APs with a pair of MR44s. I recreated the 2 SSIDs with the same PSKs and all of my Apple Phones, MacBooks, PCs, and Echo devices all connected immediately with no issues.
None of my Roku, Chromecast, LG TVs, or Amazon IoT plugs connected. When I try to directly configure any of those devices, they are not able to see either SSID to try connecting. I tried adjusting settings and also creating a test SSID with open auth 2.4 and 5Ghz, and all speeds allowed but no love. I am running the latest firmware on those APs.
Since this behavior is seen across multiple older clients after the change, I have to believe it is a setting of some sort preventing connection but I can't seem to figure out what it would be. Any suggestions or ideas?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try disabling 802.11ax features under radio settings, radio profiles:
Make sure to either disable band steering or disable 802.11ax on both 2.4GHz and 5GHz bands.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
on the firewall & traffic shaping page is the first rule for Any to Local LAN set to allow?
also, what addressing mode are you using on the SSID? if NAT mode that's likely your issue and change it to Bridge mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, I see the first rule to Destination Local LAN is set to allow, the second rule is allow any.
I have tried both NAT and Bridge mode which did not seem to change the behavior.
Edit: Also using bridge mode for the open test SSID.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Disable band steering on the rf profile assigned to your ap's
Did you also set lowest rates on the rf profile?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Use bridge mode and disable band steering.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Got it figured out. Default AP policy was 5Ghz only and overriding the settings of the SSIDs.
