SSID Availability per network
jayg1
Is it possible to configure the availability for an SSID to be different on a per network basis?  We would like to keep our number of SSIDs lower.  As a school district, we would like to have our Public network available all day in some buildings while only making it available afterhours at other buildings without having to create a separate SSID.
2 Replies 2
Yes, ssid configuration can be done per network
https://documentation.meraki.com/MR/Other_Topics/SSID_Availability
jayg1
Thank you for the reply.  However, I am looking to change the SSID Availability on a per network level, not control which SSID broadcast on which APs.  I would like to use one SSID from my template and have it broadcast 24/7 on access points in one network, and only 15:00-7:00 on other networks.  Similarly to how you can override the SSID password at the network level.
