SSID Availability - Tagging
A_Vijay
Hi Team,
I have enabled SSID availability on our network. Till now, we have installed more than 160 Meraki APs. I have tagged 91 devices for SSID availability, but most of the devices still broadcast the disabled SSID publicly. 10–15 devices only disabled that SSID.
Could anyone help me mitigate the issue?
9 Replies 9
Can you show your configuration?
Both the TAGs applied to the APs and the SSID availability configuration.
It's a relatively simple setup, so you're probably forgetting something.
A_Vijay
Hi Alemabrahao,
I have shared the configuration. Please let me know if I missed something.SSID_Availability.PNG
And how are you so sure that the APs that don't have the TAG are transmitting the SSID? Did you go to the location and see the SSID being transitioned? Do you go to the AP status page?
A_Vijay
Yes, I went to the location, and I was able to connect the AP successfully, which doesn't have the tag.SSID_Availability_Client_Connection.png
I  suggest you open a support case.
Malwina
Would be great if we could have more information regarding your setup as there could be some caveats to it.
For example, adding multiple AP tags in a single VLAN tag could result in the VLAN ID not applying correctly and therefore SSID availability not functioning as expected.
A_Vijay
Hi Malwina,
I have shared the configuration details in a reply message for Alemabrahao.
I added a single AP tag to a single VLAN tag, but I added the AP tags for more than 90 of the 160 APs.
Are all of these 160 APs in the same network?
If they are in different networks you'll need to configure SSID availability in each network (unless you are using a template).
A_Vijay
Hi PhilipDAth,
All of the 160 APs are on the same network.
