We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
I use tp-link RE200. It works fine with MR33.
But then I keep receiving alerts of the rogue DHCP server at the address of the RE200.
Any suggestions to set the RE200 DHCP valid or avoid the alert?
Thanks.
Solved! Go to solution.
Do you have a meraki switch?
Then you can allow the server or disable the message @ switch > DHCP servers & ARP
Great suggestion. I just blocked it and will see if it works.
