Roaming Surface Laptop 4
MarkB77
Just browsing
Has anyone had any success changing the the Roaming Aggressiveness on the Intel Wi-Fi on Microsoft Surface devices ? Clients are roaming constantly even when connected to an MR56 AP with good signal.
9 Replies 9
You can try disabling the lowest bit rate on RF profile.
MarkB77
Just browsing
What bitrate would you suggest ?  we have about 11 APs on this particular floor, less than 150 users.
try active from bit rate 12 or 24.
Brash
Check the Intel wifi nic driver version if there's and known bugs or updates
I have run into LOTS of problems with the Intel WiFi chip set on Surface's.
I would disable power saving on the WiFi NIC with these commands to save yourself a lot of grief:
powercfg /SETDCVALUEINDEX SCHEME_CURRENT 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a 0
powercfg /SETACVALUEINDEX SCHEME_CURRENT 19cbb8fa-5279-450e-9fac-8a3d5fedd0c1 12bbebe6-58d6-4636-95bb-3217ef867c1a 0
It could also be because of the AP performing client balancing (offloading a client to a less used AP).  You could try turning this off:
https://documentation.meraki.com/MR/Radio_Settings/RF_Profiles#Client_Balancing
If client balancing is causing your roaming - you could also hurt the WiFi network performance by turning it off to make sure users stay connected to the "strongest" AP.
MarkB77
Just browsing
Wonder if we are seeing this more due to active balancing on 29.x if that's now enabled by default
That could easily be it.
MarkB77
Just browsing
Just checked and there are no 802.11v events in the logs even though balancing is enabled and supported on the client, maybe a driver issue...
