We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I need to document a lot of networks before a template migration.
How do I find the Basic indoor and outdoor rf profile via API?
Regards
Thomas
Solved! Go to solution.
Should be possible now https://community.meraki.com/t5/API-Early-Access-Discussions/Now-in-beta-manage-default-amp-built-in...
This will show you all the RF profiles: https://developer.cisco.com/meraki/api-v1/#!get-network-wireless-rf-profiles
thx, but no. Not the basics, which are the ones I need.
https://developer.cisco.com/meraki/api-v1/#!get-network-wireless-rf-profiles = Description:List the non-basic RF profiles for this network
You are absolutely right. Then, It is not possible to list the basic RF profiles for one network.
sounds great, but seems like the link is not accessible even though I should have partner access.
But thx anyways 🙂
