Report on 2.4Ghz clients
echa
I'm hoping I missed it somewhere but I'm not seeing a way to see all clients connected to 2.4. Is there a way to generate a report on this?
RWelch
You can go to each AP and select "connection log" to filter by 2.4GHz or 5GHz to see the clients on each AP.  That's not necessarily a report as you inquired about but does show clients on the 2.4GHz SSID.
RWelch
Or you can go to each AP and select "health" and filter by band as well to see clients on the 2.4GHz SSID.
RWelch
The "timeline" option might provide you the best option to see all 2.4GHz devices as it allows ALL APs.
