Guest SSID Password
duwijakarta21
Guest SSID Password
Currently we are having problems with Meraki's new policy where every wifi password has a minimum requirement of 12 characters etc.
but we found a bug where the generated password cannot be used until we enter the password using copy and paste.
is it possible, how do I do it if I want to change the minimum requirement from 12 characters to 6-8 characters back?
2 Replies 2
You can try contacting Meraki support, but I believe it will not be changed since it is a Meraki policy.
duwijakarta21
ok thanks for the information, meanwhile I have another alternative to simplify the password even though it has to be 12 characters
