Regular DHCP errors/dropping from wireless network
SnapperJT
I'm seeing lots of DHCP failures on the network, for no apparent reason.
Looking at Wireless Health and in the logs, a number of clients are showing DHCP server failure to respond.
I am seeing some performance issues, and I believe it's related to this.
This is a very simple setup, an MX68 in bridge mode as I have LAN connected printers etc, single VLAN and two APs, one as gateway, and one as mesh.
Any ideas?
Thanks in advance!
7 Replies 7
jfigueroa
Hello, SnapperJT
Please try going to DHCP servers & ARP and select Allow DHCP server. See if that helps.
Thanks.
Ryan_Miles
Meraki Employee All-Star
OP didn't mention having a switch. The DHCP/ARP page is a switch page/feature.
SnapperJT
yeah I dont have a switch...
I have a printer as well as a SONOS setup which seemed to require bridge mode... do we think that is causing the issue?
TBHPTL
How is the port on your MX that serves the wired AP configured?
also how is the SSID configured? what mode  Bridged or NAT
SnapperJT
How do I check the port config for the wired AP? What am I looking for?
The SSID is configured in Bridge mode. I understood this was required in order to access other LAN assets like the Sonos and the wireless printer.
jfigueroa
On dashboard.
SnapperJT
Thanks for that. Are you able to be specific?
