Reducing Multicast airtime
RaphaelL
Hi ,
We have a fairly large Meraki setup. Approx 5500 APs scatered on 800 sites. Some sites are super small , and some have more than 40-50 APs.
https://www.ciscolive.com/c/dam/r/ciscolive/apjc/docs/2025/pdf/BRKEWN-2046.pdf
This document seems to suggest that we should block mDNS to save some airtime.
This video is also a great one : https://www.youtube.com/watch?v=miRV8qDOKBE
We have 4 SSIDs.  2 of them are for Guests with L2 isolation , 1 for IOT and 1 for Corp  ( no L2 isolation on both ).
We have 0 use case for mDNS on Corp.
For people that have medium to large campuses , what do you do about it ?
EDIT :  IGMP snooping is enabled , Flood unknown multicast is disabled  , Multicast to Unicast conversion is enabled.
5 Replies 5
In my case, I usually do the following:
On the corporate network: I completely block mDNS.
On guest networks: With Layer 2 isolation, mDNS is irrelevant, so I block it anyway.
On the IoT network: I allow mDNS, but I use Bonjour Gateway and filter only the necessary services.
Consider enabling IGMP snooping and multicast-to-unicast conversion, when available.
RaphaelL
So you did create a L3 rule to block UDP 5353 on your corp ssid ?
And yes M2U is enabled and is enabled by default
Yes, to be honest, our network is quite restricted, so we only allow what is necessary.
RWelch
Thanks for sharing the video (had not seen it before) but have seen BRKEWN-2046 slide deck before.
Good stuff.
That is a great video and provides a lot to think about.
