Export Maps from Dashboard into a .gif (or similar)
Jamieinbox
The Why: Now that wireless itself if a platform, we are working to get a safety locationing application using the Cisco APs to Blutooth beacon.
What We Need: To export all our maps with the location of the APs.
I will start looking around in the APIs, but has this been done before. Using the snipping tool map by map floor by floor seems -- not so great.
Totally open so suggestions. Thinking about giving the 3rd party vendor access to the platform, too.
Question: How to do this, or what's the smart way?
Thanks!
I've never tried it and don't want to need to, but you can try these two APIs.
GET /organizations/{organizationId}/floorPlans → retrieves all floor plans.
GET /networks/{networkId}/devices → retrieves device info, including location.
https://developer.cisco.com/meraki/api-v1/get-organization-floor-plans-auto-locate-devices/
You can combine these to build a structured export (JSON or CSV) for your vendor.
2 Replies 2
Jamieinbox
You are awesome- super thanks!
