RF profile creation failures using API
siya
Hi Team,
Could someone share if there are any changes with respect to RF profile creation payload?
I was using the similar payload mentioned in the link below it was working now it's giving internal server Error 500.
https://developer.cisco.com/meraki/api-v1/create-network-wireless-rf-profile/
Thanks,
Siya
2 Replies 2
I suggest you make sure your payload matches the latest schema provided in the API documentation and double-check for missing or incorrect parameters in the payload.
Main10ence
Hello @siya,
I'm more than happy to help!
Are these errors consistent or sporadic?
Is there a specific parameter that you feel is responsible for the 500 error? Have you tried to POST a small to benign change, like increasing or decreasing the transmit power by 1?
I believe that I've found a workaround to this issue. Please try the following steps:
1. Enable band steering on all SSIDs with both 2.4 and 5GHz enabled
2. Run an API that has had constant failure to see if we get a 200 code
3. Disable band steering where is was enabled in step 1
4. Test again that same API
.ılı.ılı. Cisco Meraki
Network Support Engineer
"The future favors the bold."
