You’re correct. Upgrading from Meraki MR32 APs to MR57 APs is not just a simple swap due to the significant differences in their capabilities. The MR57, with its 4x4:4 MIMO, 5GHz ports, and WiFi-6E support, is a much more powerful device compared to the MR32.
Performing an RF assessment before deployment is indeed a good practice. This can help ensure that the new APs provide the correct RF coverage and don’t overlap with existing channels. It’s also important to consider the placement of the new APs. While the MR57s are more powerful and could potentially cover a larger area, the actual coverage will depend on factors like the physical layout of the space, the number of devices connecting to each AP, and the types of applications being used.
Simply replacing an MR32 with an MR57 without considering these factors could lead to issues like co-channel interference, inadequate coverage in some areas, or even too much coverage in others, which could cause unnecessary roaming.
