- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Question about way to set up authenticating wifi users with purely custom or meraki certificates
We're trying to set up for wifi user authentication using custom or meraki provided certificates, without using username or password to access wifi network.
So that only office PCs having certificates can access office wifi network.
Can someone explain how to or where to setup it?
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This would be done using machine authentication and a RADIUS server. It's not crazy difficult but does require you having a PKI and RADIUS server.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Or you could use Systems Manager (with Sentry) to fully control your devices, including providing an appropriate WiFi profile. With this option Meraki provides the X.509 certs and cloud RADIUS.
https://documentation.meraki.com/SM/Deployment_Guides/Systems_Manager_Sentry_Overview
If you can't or don't want to fully manage the devices (maybe they are staff-owned?) then consider Trusted Access
Ether of these options will require you to purchase Systems Manager licences for the devices requiring connectivity.
You may still need to use username and password as an initial means of setup - after all, you still want to check what's connecting to your network to start with, right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I think it'll help you.
