Problem with Local Authentication
Bdcvc
We are trying to get Local Authentication to work on a MR33 access-point with latest firmware.
We already checked message:
https://community.meraki.com/t5/Wireless-LAN/Local-Auth-issues-with-Android-devices/m-p/196714
Our infrastructure is as follows :
- Azure AD environment with Intune
- Scepman certificate service
- Client Certificate CA installed : Scepman Root CA
- LDAP Server CA installed : {our Azure LDAP cert.)
The LDAP Server test (built-in test tool in GUI) is succesful.
A windows 10 client with both Client and Root CA certificate installed cannot connect to the (SSID) network.
A Wireshark packet capture only shows initial connection to the AP, but there is no response from the AP.
The capture also does not show any traffic to our Azure LDAP server.
We will appreciate any help in solving this issue.
Thanks.
Bdcvc
Hi, we just resolved this issue.
Solution : Install the IdenTrust Root CA 1 certificate on your end devices.
Please refer to : : https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Local_Authentication_-_MR_8...
2 Replies 2
Can you share the error you are receiving?
Bdcvc
