- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Port running LACP and LACP has disabled this port
I get this message when I connect my second fiber for redundancy. but I get this message
I have 2 core
core 1 port 5 to sw systems port 49 everything is fine, but in core 2 to port 51 I have problems, I get this message and it is disabled as soon as I connect it. I have all the correct settings. The problem started when I disconnected the port and reconnected it. Before that everything worked fine.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which device are you referring to? Can you provide information on the model please?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
MS425-16 core
MS225-48FP sw sistemas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mention in the discussion of the link below.
"Link Aggregation/EtherChannel/Port-Channel uses different methods of bundling multiple ethernet links into one logical link. Link Aggregation (LACP), Port Aggregation Protocol (PAgP) or "mode on". The terminology is often used interchangeably to describe link bundling. For example, certain Cisco platforms (Catalyst) use the command "show etherchannel summary" while some (Nexus) utilize "show port-channel summary". In short, they are referencing the same feature.
Meraki MS supports LACP only which means that both ends of the link(s) should be able to talk 802.3ad. "
https://community.meraki.com/t5/Switching/Port-aggregation-not-working/m-p/101200
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What does the event say for the reason the port was disabled?
Try giving the port a cycle in the dashboard.
