With my fortigate, I wish to access the Meraki AP.
The issue is that the AP is not coming up even if the SW is coming up after I inserted a static IP address inside the range.
Any thoughts?
SW
AP
port AP
FORTIGATE SIDE
Solved! Go to solution.
As per your pictures... You need to set the native VLAN on the port that connects to your AP (port 11) to VLAN 40.
Keep it as trunk and put the native VLAN on that port to VLAN40
Check if the AP is receiving IP and review your firewall policies.
I also suggest opening a support case.
In that case, also remove the 40 from the vlan field of the ap management address
You need to get it to the point that if you plug a notebook into that switch port it can get Internet access. Perhaps start at that point, and once that works plug the AP back in.
thanks for your reply @alemabrahao @PhilipDAth @Purroy @ww
@Purroy i putet the native vlan like 40 and @ww cjhange the mgmnt the AP comes up without tag thanks guys
