IDS alerts are usually generated by MX appliances, which have no concept of the SSID (unless you are using an MX with built in WiFi). So there is no way for Meraki to provide this information.
You might have vlans configured, and if you map an ssid uniquely to a vlan then I guess you have your mapping.
