Hello.
I have a (10) MR46's indoor and (2) MR76's outdoors. Everything works well except for one of the outdoor MR76's and wondering if I am expecting too much out of it, in terms of signal distance & strength.
There are VERY FEW users on that AP, the ground is basically flat and the only thing in-between the AP and the desired usage areas is a medium sized willow tree.  The desired usage distances are between 120 feet to 200 feet.
I've included a photo of the AP & antennas (of course this is not a photo of it installed; I brought it into my office to look at it closer).
I often time loose connection and need to walk closer to that AP... are my exceptions too much here?
If it's simply a matter of being too far away; do you think the newer MR86 would yield better results?
Thanks!!
