Upon configuring an MR (i.e. MR46E) in Cisco Commerce, does the license come with the AP's or do they need to ordered? If yes, what or where can I find the SKU's?
Thank you.
Hi @johnnyngena,
You need to order the licenses. You can estimate the cost on this link:
https://meraki.cisco.com/product-catalog/wireless-lan-mr/
Thank you alemabrahao, got it conifgured in Cisco Commerce.
MR (AP) license SKUs are listed here
Thank you Ryan. I'm assuming its the same license (LIC-ENT-3YR) for both the MR46 and MR64E?
Correct.All access points (MR's) use the same license SKU's.
Switches (MS) and Security Gateways (MX) have license SKU's that differ depending on the model.
As said above, they're purchasable SKU's.
Also good to be aware that with co-terming (the dashboard default), the license usage starts ticking from date of purchase, not date of activation.
Thank you for the reminder Brash!
