No internet connectivity for some wifi clients
jrworley
Symptom:  Some clients once connected to our prod wifi can not get out to the internet.
Clients get an IP assigned from the correct scope, correct DNS and correct Gateway but cant get to the internet.
Can ping from the Client to the L2 switch but could not ping the gateway or to DNS
Gateway can ping clients from portal
work around for this so far is to set a static ip on the pc and then you can get out to internet.  Then set back to DHCP and it works properly.
Mx105 Current version: MX 16.16
MS210 -Current version: MS 14.33.1
MR56 -Current version: MR 28.6.1 scheduled to upgrade tonight to  MR 28.7.1
jrworley
Resolved -
We had two overlapping networks in the organization causing the intermittent issue.
8 Replies 8
Who Is your DHCP server and Default gateway. Have you performed a packet capture?
jrworley
The MX is the gateway and the DHCP server.  Have not been able to run a pcap yet
If you configure some port on your MX or switch in the same VLAN, and connect a notebook with the internet cable, Do you have this issue?
jrworley
Unfortunately Im not on site at the moment.  I will check next time im there
BlakeRichardson
Hmm the fact if you set something to static and it works seems odd, can you confirm the DHCP scope is correct?
jrworley
yea DHCP scope was correct and its been in prod for about 6months with no issues.  This has only happened with 3 devices so far.    Only about 26 users there and they have a /23 pool.
jrworley
Resolved -
Brenda_Brown
Just browsing
How did you identify the overlapping network?  I am having a similar problem for any Windows PC devices that come into the building, especially if they roam throughout the school.  I only have Meraki APs - mostly MR46s.  If they are too close together, would that cause a network overlap?
