New name, same great feature - MS and MR SecurePort
Minyi
We would like to inform you that the MS and MR SecureConnect feature, which enables the secure automation of MS switch ports configuration connected to MR access points, is now SecurePort.  This name change will simply allow us to clarify the feature functionality.
The functionality of the feature remains unchanged on the dashboard.  However, please note that this name change will impact the following API end-point, where customers will need to modify the key ‘secureConnect’ to ‘securePort’ on their API calls:
1.https://developer.cisco.com/meraki/api-v1/#!get-network-settings
2.https://developer.cisco.com/meraki/api-v1/#!get-device-switch-ports-statuses
Check out this new feature announcement post and learn more.
1 Reply 1
Inderdeep
@Minyi : Thanks for the update
www.thenetworkdna.com
