New Wireless RC 31.1.6 - Lots of Fixes
Mloraditch
Lots of Bug Fixes, several having to do with Radius that sound suspiciously like random forum posts I've seen!
EDIT: "Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)" was moved to fixes by Meraki after the original post. Very very long outstanding bug that may finally be fixed.
Important note
Bug fixes
  • General stability and performance improvements
  • MR56 ethernet port flaps occur when connected to C9300-48UN(V04) at 5Gbps speeds
  • MR57 ethernet port flaps occur when connected to MS355 at 5Gbps speeds
  • MR46 not responding to Probe Requests from clients
  • Channel & power not configurable via LSP on CW9163E APs
  • Wildcard NAS-IPv6-Address AVP sent on config change (Wi-Fi 6, Wi-Fi 6E APs)
  • NAS-IP-Address discarded (Wi-Fi 6, Wi-Fi 6E APs)
  • RADSec authentication failures (Wi-Fi 6, Wi-Fi 6E APs)
  • DHCP offer is not forwarded if broadcast flag is set (Wi-Fi 7 APs)
  • mDNS traffic blocked (Wi-Fi 7 APs)
  • SSIDs broadcast on 6Ghz despite being disabled when using WPA3 transition mode (Wi-Fi 7 APs)
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)
13 Replies 13
RaphaelL
Most important part : 802.11ac Wave 2 and older products will only upgrade to the backup version (MR 30.7.1)
RWelch
Exactly ( ↖️🎉
Paccers
@cmrin shambles after being beaten to the release notes post 😏
Just sharing the love @Paccers 👍
Paccers
For me the 'Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)' item is listed under 'Bug Fixes' section
RaphaelL
Same here but I swear it was listed as a known issue. Might be a corrected typo
Mloraditch
Yes i see that now too. I definitely just copied and pasted so they must have edited. Crazy if that's finally fixed
meraki-chris
Yes, that was a correction - moved to bug fixes
RWelch
@meraki-chris 👏 👏 👏 🎉
lotsofdots
I perfromed a rollback on my MR36H to MR 30.7.1. As posted already with MR 31.1.5.x, I also experience lags with MR 31.1.6 during longer Webex Calls (>30 minutes) and other usage like streams or "high" bandwidth and low latency connections. After 50 minutes call today, I even got a short loss of connectivity. With MR 30.7.1, at least with my MR36H in use, I have no issues. Someone else epxerience lags with MR36(H) and MR 31.x?
NolanHerring
Were you able to get anywhere with support?  I just upgraded a site to 31.1.5.1 2 weeks ago and been having issues, and was planning on upgraded to 31.1.6 but seems like I might be better off just going back to 30.7.1
Site has a mixture of MR42/MR46E/MR44. Since the upgrade the site has been complaining (everywhere) about slow connections, random disconnects, trouble connecting.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
lotsofdots
I only posted my question in this forum. I did not raise a support request. But no update to my question in the community post yet.
I downgraded to 30.7.1 and have no issues with the MR36H. With 31.1.6 or the earlier 31.1.5.x release I have had the issues you described, too.
Paccers
This was promoted to Stable as of yesterday (15 days!), record time for Stable RC to Stable move?
