- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
NAT Mode
I have a simple question:
What VLAN does traffic from a SSID set to NAT mode traverse?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So if the AP has an IP address 192.168.5.0/24 on vlan 5, traffic traverses on vlan 5.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The implications of enabling NAT mode are as follows:
- Devices outside of the wireless network cannot initiate a connection to a wireless client.
- Wireless clients cannot use Layer 2 discovery protocols to find other devices on either the wired or wireless network.
- Legacy VPN clients (i.e., those that do not support NAT Traversal) may not be able to establish IPSec tunnels over the wireless network. (One workaround is to upgrade the VPN client or configure the VPN client to establish an IPSec tunnel over TCP, e.g. SSL.)
- VLAN Tagging wireless traffic is not supported in NAT mode.
Please note that each AP will NAT to its own management IP address. As a result, LAN flows will be interrupted when the client roams between APs.
The DHCP service for NAT mode will only hand out addresses in the 10.0.0.0/8 subnet. SSIDs in NAT mode can still be used on wired networks already using a 10.x.x.x address space, however clients on the NAT SSID may be unable to communicate with these networks.
Use Cases
NAT mode works well for providing a wireless guest network, since it puts clients on a private wireless network with automatic addressing. Layer 3 firewall rules can also be used to quickly limit or block access to network resources.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I saw that article, but it doesn't answer the question.
- Does this mean is it untagged traffic?
- Does traffic traverse the native VLAN since it is "untagged?"
- Or since it is NATing the management IP does it traverse the management VLAN?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I suppose it is, but then again, I'd normally only use Meraki DHCP on deployments that quickly need guest WiFi, and only able to use single vlans.
Then again, all clients are isolated from eachother. No client can talk to eachother in NAT mode. Internet access only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm wondering which is more secure, NAT mode or Bridge mode with a L3 rule blocking access to the local LAN?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@RobMcLean NAT mode by default blocks access to the LAN unless you change L3 rules. Just letting you know. 😏
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for all the replies.
I think I am going to go back to a bridge mode guest network , if for nothing else than a more seamless roaming, but I do want my management traffic completely separate.
Perhaps if the alternate management IP feature comes out of beta, there will be a way to keep them separate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
How do we migrate wireless clients from Meraki DHCP(NAT Mode) to an internal DHCP server(Bridge Mode) seamlessly? Any Suggestions.
