Hi, thanks for coming back.
Would the best solution to control the AP transmission power levels be to:
Create one Radio profile, specifying per SSID and the transmission power
Create each SSID with the desired frequencies e.g. Corporate 5 Ghz only, Guest 2.4 and 5 Ghz
The apply the single Radio profile to the AP, so each SSID uses the desired bands but a single Radio profile manages the transmission levels?
