Multiple entries of single SSID
saurabh_F1
We have configured a single SSID on our Meraki dashboard, but when we try connecting to it on a Windows laptop, we can see multiple entries of the same SSID with suffix as number 2,3,4.
e.g. Cisco, Cisco2, Cisco3....
We had opened a TAC case, but the engineer said that there is some problem with Windows.
Please advice.
SoCalRacer
Have you tried connecting from different Windows devices? Android? iPhone?
Yes, it doesn’t show on Android, only on Windows.
Good place to double check some info about multi-SSID environment
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Multi-SSID_Deployment_Considerati...
If this is a Windows issue, I would try a couple things.
1) Network Reset
https://support.microsoft.com/en-us/help/10741/windows-fix-network-connection-issues
2) Use GUI to remove networks
https://kb.netgear.com/29889/How-to-delete-a-wireless-network-profile-in-Windows-10
3) Remove SSID from Registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles
Asavoy
I would make a batch file with the following commands to run, then run as administrator-
netsh wlan delete profile name="xxx" interface="Wi-Fi"
(where xxx = duplicated wifi name, copy/paste for all duplicate instances)
netsh int ip reset
netsh winsock reset
shutdown -f -r -t 5
It's definitely a Windows issue. On the machines that you're seeing this on, is there OEM wireless software installed? On Dell laptops there's a ridiculous OEM program called "Dell Unified Wireless Suite" that has wreaked havoc for me on occasion. I always remove any OEM wireless software and just force drivers only install.
