Hi Guys
I have a hybrid switch setup with HP and cisco - native vlan is 1 and cannot change this. Vlan 1 is an uplink to the data MPLS that is the data circuit WAN separate to vlan 352 a internet breakout.
I have a guest internet facility over wifi and that works fine in a L2 bridge mode with the MR34's connecting via an access port to a vlan with 200mb internet backhaul, that is separate to my corp data. My merakis are currently plugged into vlan 352. Vlan 352 is a internet connection with dhcp provided to the meraki from the router.
I need to add corp-ssid and I have managed to get it working a test meraki with radius and NPS. This is in NAT mode and at the moment setup as a trunk port with a connection over vlan 330. vlan 330 is data for the org. As a trunk port and the management plane of the merakis are on vlan 1, thats works fine.
I can see that i can setup the meraki on native vlan 1 for the management plane of the device. So if I trunk the uplink port i can easily setup the corp-wifi on vlan 330 and tag the ssid. How do i deal with the guest wifi on vlan 352, i cannot tag this in the SSID page as it is a bridge mode and that doesn’t know about vlans.
So how do I deal with this? It seems like i cannot mix nat mode and bridge mode on the same AP's. Has anybody found a way around this issue?
I cannot put guest internet traffic over vlan 1 as this is low bandwidth and separate to the corp data.
