We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Is it possible to schedule SSID availability using the API, beyond the one schedule per day limitation that exists in the web interface?
Solved! Go to solution.
Not with just the api.
You need to schedule (at a server/host) the api calls (enable/disable ssid) at the specific times.
