Motorola 9090 and Meraki WiFi
Craig_PA
Having issues with Motorola 9090 RF Guns and Meraki 64E.
Motorola RF Guns running Windows Mobile 6.X and when the come out of sleep, it disables the WiFI NIC on the gun.
All combinations of Power Settings have been tested (CAM, PSP, MAX) to no avail.
Nothing obvious on the Meraki side. Have disabled UNII 2 and 3 as a test. Issue occurs with device stationary and seeing good signal strength from the nearest AP.
Any input appreciate. We are at wits end as this is occurring at several sites.
What type gun is it exactly,  does it even support 5ghz?  If i google it i only see very old devices.
Did you try running a 2.4ghz only ssid? With lowest bitrate support
Craig_PA
Motorola 9090. And yes, they are very old.
That is a good point. We have avoided doing that for channel plan reasons AND the guns were successfully running on 5ghz. We are currently running 5ghz at its lowest mandatory bitrate ( 6 mbps )
Thank you for your reply.
They have run fine on meraki? Or previous wifi solution?
Did it start after a firmware update?
You could try disable things like band steering and client balancing in the rf profile
I personally don't see any problem related to Meraki in your case.
