Meraki switch bridge mode question
Keith_Li
Dear All,
                 I got a question would like to ask as i'm currently using MS-240-12P with AP MR44 & 76 in bridge mode, endpoint to endpoint could ping and reach each other, and just wonder there will be no port blocking in bridge mode right as i checked in Firewall & traffic shaping with specific ssid, its set to all allowed in local lan in wireless client accessing to lan, as customer reported the endpoint which connect to ssid could not print with airprint, as far as i know there is no port block at all within the bridge mode, please correct me if i'm wrong
Keith
6 Replies 6
rhbirkelund
If the SSIDs are set to Allow Local LAN, then there is nothing blocking clients to talk to eachother.
If you need to use Airprint, you might need to enable Bonjour forwarding on the SSID.
Keith_Li
so i add a rule under Bonjour forwarding with specific vlan and all service ?
There is the documentation.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Bonjour_Forwarding
Keith_Li
May i ask if it is for airprint services printing from mobile to the printer, for catalogue i should choose "printer" ?
Yep.
Keith_Li
let me try thank you
