Meraki local authentication
Ajchan
For Meraki local authentication with an LDAP server what are the Pre-requisites ? and is certificate must or is it optional if i am going with only LDAP & not LDAPs ?
1 Reply 1
 Requirements
  • All MR access points in the Network must be running MR 27.1+ firmware*
  • An admin account credential for the LDAP server with read-only permissions has to be input as part of dashboard configuration
  • If an Active Directory-based LDAP server is used, it must support an LDAP bind operation
  • The LDAP server must support STARTTLS
  • CA certificate used to sign the LDAP server's private key must be uploaded to the dashboard. This certificate is used by an MR to verify the authenticity of the LDAP server.
  • The LDAP server’s certificate must have a subjectAltName field that matches the Host address configured on the dashboard (either IP address or FQDN)
  • Wireless clients must trust the certificate presented by the MR which is signed by a well-known Certification Authority QuoVadis for the purposes of validation of the MR for certificate-based authentication.
    https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Local_Authentication_-_MR_8...
