Meraki dashboard add map question
Keith_Li
Dear All,
          I was trying to add a map in meraki dashboard, how i can make 100% of opacity by default and hide the google map at the background ? look like everytime i need to manually change, any help would be appreicated, Thanks
keith
You will always have to change it manually.
8 Replies 8
UKDanJones
Why are you trying to hide the google map? You should overlay your floor plans so they fit on the Google map. This will be needed in the future for outdoor 6 GHz and FTM any way.
Please feel free to hit that kudos button
Keith_Li
our customer insist want to hide the google map, just wonder if i can make below setting permanently ? thank you
UKDanJones
No you can’t.
Keith_Li
noted, just wonder any officaly documentation mention this so that i can share to our customer, Thank you
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Using_a_Floor_Plan_...
Keith_Li
although i defined floor plans and define the opacity of the floor plans on top of the map view, everytime when i logout and relogin, the opacity and map view will changed it back, as i have select MAP TYPE as floor plan only & opacity 100%,  but it will changed back to "map" and opacity 60% itself,  or it needs manaully change everytime ?
Keith_Li
clear thank you for your help
