Meraki authentication email filter
Elvin_Hajiyev
Hi all!
We're using Meraki authentication with self registration, so people can create their accounts from splash page by themselves.
Is there any option to allow only emails from specific domain to register and authenticate on Meraki splash page?
We need to be sure that only users with corporate mails (for ex. @company.com ) can authenticate on splash page.
Thanks in advance.
BrechtSchamp
Not within the default Meraki self-registration guest I'm afraid. You'll have to look at either using the captive portal API to create your own splash portal, or look into the 3d party solutions out there:
https://apps.meraki.io/apps/?category=Guest+WiFi
Bettencourt
Hello there!
You can use a sponsored guest.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Sponsored_Guest
It's not exactly what you're looking for, but it allows only people with a certain domain name to log in to the WiFi.
Yes, this is a little different approach. However, thanks for reply!
